two Whip Audio speakers(200watts/100wattsRMS) in the front with O2 tweeters (70Watts/40RMS)
I have two Alpine type R in the rear(275watts/55RMS) replaced the tweeters with O2 (Same as above) because they blew...
I Have a Rockford Fosgate 301x amp for the interior speakers...Amplifier Type:
Multi-Channel
RMS Power @ 4 Ohms: 40W x 4
THD at 4-Ohm RMS Power: 0.05%
Bridged RMS Power @ 4 Ohms: 150W x 2
Speaker Level Inputs: yes
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: None
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 100 dB
Fuse Rating: 30 amps
I have a Rockford Fosgate P5002:
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS in bridged mode at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
I have it bridged powering a JBL 12" P1222 in a sealed box:
Power Handling, RMS 400 Watts
Power Handling, Peak 1200 Watts
Sensitivity 97dB
Now, I have an MTX amp 202 laying around that I want to hook up to the system:
50 WATTS X 2 RMS INTO A 4OHM LOAD
100 WATTS X 2 RMS INTO A 2 OHM LOAD
200 WATTS X 1 RMS BRIDGED INTO 4 OHM LOAD
FREQUENCY RESPONSE 20-20,000 HZ
My question is can I hook the RF 301x to the frnt speakers only and the MTX to the rears.....
I will then have 3 amps...is that ok?
I also have a crossover and 1farad cap, and a redtop optima under
Multi-Channel
Preamp Outputs: yes
Bass Boost: None
Sensitivity 97dB
