Ok here goes my assault on this particular forum
reed8857
SRT 4 (neon with balls)
I am getting
2 x Alpine SWR-1241D (specs below) Powered by Soundstream VGA800.2 (Specs Below)
I will be wiring @ 2 Ohms RMS = 400 W each
In my searching it stated that I should build the box different from what the manufacture reccomends due to the increased wattage. However it does not state what would be ideal. What would be the ideal tunning freq? Should it be ported? Perferable I would like to keep the box simple with a sealed enclosure but if I can get better performance out of the Sub with ported than I will do it that way. Thanks for any help.
I listen to everything with rap being the most predominant
Specs: Alpine Type R (DVC..but you prob knew that already)
General-Subwoofers
Diaphragm Material : Kevlar Reinforced Pulp
Magnetic Weight : 89.4oz.
Mounting Depth (top mount) : 178mm (7”)
Mounting Diameter (top mount) : 275mm (10-7/8”)
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.7 – 1.0 cu. ft.
Spider Material : Nomex
Voice Coil Diameter : 50mm
Power Handling
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Thiel Small Parameters
Coil Height (Hvc) : 37.74mm
Cone Area (Sd) : 467.59 sq. cm
D.C.Coil Resistance (Re) : 3.6 ohm + 3.6 ohm
Electrical Q (Qes) : 0.45
Equivalent Suspension Stiffness (Vas) : 58 liters(2.04cu.ft.)
Free Air Resonance (Fs) : 28Hz
Frequency Response : 24Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4 ohm + 4 ohm
Inductance (Le) : 3.85mH at 1kHz (1.34mH at 20kHz)
Linear Excursion (X linear) : 13.87mm
Maximum Excursion (X peak) : 27.7mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 8.31
Sensitivity : 87 dB/W/M
Total Loudspeaker Q (Qts) : 0.43
Amp Specs
Output(Watts) RMS @ 4 Ohms: 200W x 2
Output(Watts) RMS @ 2 Ohms: 400W x 2
Output(Watts) RMS Bridged @ 4 Ohms: 800W x 1
THD:
Signal to noise ration:: > 115dB
Input Sensitivity (Volts): 0.15 - 12.0
Crossover Slope: 12dB
Crossover Frequency: (Hz) 30 - 4k
Dimensions(INCHES) : 11.2" x 2.6" x 16.5"
RUBI (Rapid-Use Branched Impulse) proprietary power supply topology
STACT (ST abilized Apex Current Topology) Reduces power supply stress by 50%
Trident Amplifier protection topology
Hawkins Bass Control Proprietary bass equalization topology
IDI (Intelligent Distress Indicator) gives visual indication of amplifier
protection status
Harmonic Bass Alignment produces tighter, more accurate bass
Fully regulated MOSFET power supply
Triple Darlington Output Circuitry
BIP (Bias Input Protection)
Rail Stabilization Protection Circuitry
Bi-linear selectable two-way crossovers for amplifier and line outputs
Continuously Variable High and Low Pass Crossovers
Balanced Line Inputs for the Highest level of Noise Rejection
Vortex Induction Fan for Thermor Management
Platinum RCA Inputs and Outputs
Platinum 4-gauge Power Connectors
Tri-mode Operation
well he said he would preferably like to keep it simple and sealed but if he could get better performance---his definition of better may be different than me or you so thats why i recommended the sealed box--he pretty much answered his own question. but you can get awesome with either ported or sealed just depends what kind of bass your lookin 4.
ok time for a dumb question.......wait there are no dumb question.....just dumb people asking quetions.....anyways when someone says there going to tune does that imply that it is a ported box?
Ok, I know sealed is better qaulity and ported make it louder....I know its a little more complicated than that and alot has to do with personal preference. still, knowing what I just said can anyone give me the advantages to your paticular suggestion for a box....2 sealed, 1 ported. thanks
reed8857
reed8857
Atlanta/Deployed Kuwait
reed8857
