ohms?
if you have two 4 ohm subs... you can wire them in parallel to the amp which would create a 2 ohm load. the amp will be able to push the 4 ohm load (if stereo) but at lesser watts. just make sure you look at the amps specs before you buy. look for a mono amp which is stable for a 2 ohm load or a multiple channel amp which is bridgable to 2 ohms.
Brutus2600
Brutus2600
Cleburne
imral3
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
