45auto
I have 2 Audiobahn 1571SE's, and I hooked them up yesterday, looking for a 4 ohm load, I get about 6... So I check everything, and everything seems fine, so I try and test them again, I get a reading of 6 ohms again. So I take everything apart and check the subs individually... The one sub is reading a perfect 3.6 on each voice coil, whereas the other sub is giving me a 6 ohm reading, then I move it a little, and I get a 4 ohm reading, then it's back to 5 ohms.
What's going on? And how can I fix it? The actual wires leading to the center of the sub read 3.6 ohms also, but at the speaker wire terminals, I'm not getting the right thing. I was thinking about soldiering the speaker wires onto the inside of the sub, right onto the little speaker wires (spider maybe?) inside, but when the sub is moving, I figure that it's gonna come loose....
Help meh!
Help meh!
