Odyssey PC 1700
Silver-N-Black
6 - Odyssey PC 1700
Used/Dirty from being under the truck. They work great they are floating around 12.6ish to 12.7ish.
SPECIFICATIONS
Pulse (5-second) Hot Cranking Amps (PHCA) 1550
Cold Cranking Amps (CCA) 810
20Hr Nominal Capacity (Ah) 68
Reserve Capacity Minutes 142
Dimensions L x W x H (in) 13.02 x 6.62 x 6.93
Metric Dimensions L x W x H (mm) 330.7 x 168.2 x 176
Weight (lbs) 49.5
Weight (kg) 22.4
100 without the inputs and 125 with the inputs.
No shipping keeping it local for now.
Odyssey PC1700 battery found in many American and foreign made vehicles including police, fire rescue, and heavy trucks. PC1700 is a dry cell AGM battery that has 1700CA (cranking amps). Odyssey PC1700 is a true deep cycle battery, making it one of the best marine batteries for heavy drain. Odyssey's design prevents the internal plates from corrosion and sulfation - the main cause for battery failure.
Design
Rugged construction
1700 cranking amps for 5 seconds
1540 cranking amps for 10 seconds
1355 cranking amps for 20 seconds
Short circuit current over 3500A
68 amp hours
142 minute reserve capacity with 25amp load
Length 13.0"
Width 6.5"
Height 7.5" including terminals
Weighs 59 lbs
Design life: 12 years
Typical service life: 6 to 8 years
Specifications
Chemistry Lead Acid
Capacity 68Ah
Rating whr 816
Cca 810
Reservecapacity 142
Cellnum 6
Length 13 inches
Width 6.5 inches
Height 7.5 inches
Weight 59.00 lbs
Warranty 2 Year
Bci Group Size 31
Silver-N-Black
Silver-N-Black
SoCal
disturbed471985
