Sold O/S Orion HCCA 225 Digi Ref, Rare Memphis 16-EQ13 EQ/LinerDriver, Orion Cobalt 500.1
BassAddictJ
Got these from matt_bennett05 in a trade deal. Everything is 100% tested and working great.
First up is the HCCA 225 Digital Reference (2nd generation I believe), if yo know what this is then it doesn't need an introduction. It's a grossly underated bulletproof old school cheater amp built better than anything in the last decade and a half. rated down to .5ohm stereo, but is0.25 ohm stable from what i've read up on it.
stereo
25x2 @4ohm
50x2 @2ohm
100x2 @1ohm
200x2@.5ohm
Mono
100x1@4ohm
200x1@2ohm
400x1@1ohm
if you're doing below 1 ohm then make sure you have a spare battery for this to feed off of. 0.25ohm you should be in the 800w-1000w range depending on voltage and imp rise. Another cool feature not common for it's time is a peak/clipping indicator on the side of the amp. VERY helpful little feature. There's an "EQ" switch and a "MONO" switch, self explainitory.
Cosmetically it's seen better days. There's some paint scratches here or there and very end of two of the fins are sllllightly bent. I'd give it a 6-7 out of 10...i've seen MUCH worse condition amps this age. The power/ground wires were cut kind of short but there's more wire crimped securely on. Check the pics, I took a few close ups.
please note, thats not cobwebs on the side, its leftover cotton from q-tip and alchole wipe down i gave it.
more detailed pics below
115 shipped and insured.
Memphis 16-EQ13, circa 2000-2001. If this was in a half din I would keep it. If you're cool having it trunk mount (or get creative and put it in your center console) then this will rock your face. High end build quality, certainly up there with the old school white phoenix golds, eclipses, and alpines ive played with. If you have a nice front stage this will melt your face with the clarity and control it offers. Plus line driver outs....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif It is in excellent condition and tested 100% functional.
specs
Infra-Sonic processor ( i believe this is a SSF at 10Hz).
EQ In/Out - 1 pair In / 2 pair Out
7V RMS
13 (stereo) Graphic:
1/2 Octave Bands - 32, 48, 64, 90, 125, 180 Hz
Octave Bands - 250, 500 Hz, 1, 2, 8, 16 Khz
S/N Ratio - 110db
THD -
Clipping Indicator
90 shipped and insured FIRM.
Orion Cobalt 500.1
This is a newer DEI made Orion monoblock. It'll do a good 250w off 14.4v @ 2ohms. For what it lacks in power output it makes up in cosmetics. It's in good condition and has a nice color fade from dark to copperish near the bottom. Pics dont do it justice. Also when powered up the blue line across the middle illuminates and it looks pretty sweet.
70 shipped and insured.
Paypal is JayM_Productions@yahoo.com. send payments as gifts or add 3% for feeez
more pics of the 225 sides. I cleaned more of the grim off, the amp cold use some more TLC. it would certainly shine again minus the paint scuffs. enjoy
BassAddictJ
BassAddictJ
FL
BassAddictJ
