no RCA sub output from alpine HU
dmc
I recently put an amp and 12" sub into my car. When I plug my ipod directly into the amp, the subwoofer works great. However, I can't get any sound to my amp from my head unit. The output to the stock speakers works perfectly.
I tried two sets of RCA cables, so I figured that my HU must be busted. I called Alpine and they gave me the same response. However, I bought an identical HU today and the new one doesn't work either!
I don't know what to do at this point, the only components that could be failing are the RCA cables and the HU, and I swapped both of them. I have the cables plugged into the subwoofer jacks, and I verified with Alpine that my HU is set up correctly.
Any ideas?
Are you shure the sub vol is turned up to 15? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
yup. I have the following:
subwoofer is on
sub output is max
bass is max
The remote on/off wire from the HU to the amp is working, since the amp power light goes on when the HU is on. Also, i hear a little pop from the sub when the amp turns on.
I checked to make sure my HU's ground is good, it is.
When I touch the RCA cables on HU side with my hand, I can hear the sub move a bit. I also tested the cables with a multimeter, they're good.
yeah on my HU, my sound bass just quit one day, so i ended up testing everything i possibly could think of. opened up the amps, nothings wrong, check the wiring, perfect. i couldnt figure out what it was. so i hooked it up to my rear outs, instead of my sub out, and waallaa. it worked. maybe try that^^^
solved!
Here's what I did:
I got an adapter to plug headphones into the RCA outs of the head unit. All three sets of output (front, rear, sub) worked!!!! I plugged the sub back in, no luck.
Then, I plugged headphones into the sub RCA jacks on the amp side of the cable. That worked too!! At this point, I suspected some bizarro grounding problem. I set up the following:
RCA cable from HU -> RCA to headphone adapter -> headphone female to female adapter -> headphone to RCA adapter -> amp input
Voila, my amp worked!
Now get this: I unplugged the set of adapters, and went right from the RCA to the amp (the setup that never worked in the past). It worked this time!
Right now, my amp is grounded to the trunk latch. I'll be moving the ground to a better place soon, and I'll let you know how it works out. Thanks for all the help! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so after you did all the adapters, you unhooked all of them and hooked your RCA's back up and it worked fine?
Yup.
Maybe there was a charge in the HU or amp that had to be grounded out?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
dmc
dmc
North America
Calikid
