No flaming, no bytchin', just read it.
yeah, slap that anti-bush sticker on the car even though he was president for a whole year before it happened and we knew about bin-laden and his ilk for about 5 years before it.......if anything, clinton had a good bit more to do with "letting" it happen
It ends abruptly, and there's no resolve. You can just tell from reading it that the terrorist was a soft emo, an introvert just looking for a source to vent. Too weak to *******, too scared to cry. The attack wasn't this big attack on the US to him, it was nothing more than a weak cry for help. Like the emos that realize a gun works better than a knife and puts a hole in his temple after writing a ******* note that ends with "help me".
When the plane hit, it caused so much heat that gurders were vaporized in the process, so I can only guess that Marwan al-Shehhi gets to burn twice.
"gurders" were vaporized eh? not physically possible....there is no way that jet fuel can burn hot enough to even melt or stress the steel used in WTC....which was UL certified to 2x the temp that jet fuel can put out
Any way you want to look at it, the buildings fell. If the fuel can't burn hot enough to melt or vaproize the girders, and the same steel used to hold up all the building is used to hold up the top 1/4 only lost 1/2 it's strength, then the heat and impact wasn't physically capable of causing enough stress to down the building. Something was not accounted for. The fuels used by jets had gone through decades of refinement and improvement since the towers were built, and those same decades took their toll on the steel used to make the buildings.
metal bending causes its own heat. that coupled with the heat generated from the diesel fuel and the mass of material burning in the building...it obviously was able to "vaporize" human bodies, and structural components of the towers. More than just jet fuel must be factored into the collapse. The weight of the floor collapsing carried the weight of all floors above it and created a deadly chain reaction. It's so sad.
bonesninja
bonesninja
Lima, Ohio
reneeb7363
