no bass in cold
Beaver1992
Boom Boom Boom
551
NC
Well recently its gotten colder where i live and early in the mornings i have no bass till it warms up in my car. It takes like 5 to 10 mins to come on and itll just come on in the middle of a song. But when i get outta school its warmer and everything works fine. Any ideas
I have the same problem some mornings during the winter. In my case everything just gets very cold. The sub "freezes". The surround will stiffen because it's made of rubber or foam; both of which do not like extreme cold. Just don't try and bump in the mornings because you can cause some permanent damage to ur stuff
but the sub dnt move at all then all of a sudden it cuts on. its a new american bass TNT that just came out
how cold is it? if its that cold, chances are your woofers surround is hardening up from the cold, then loosening up the more you play through it.
It's DEFINITELY not the sub being cold. Mine always play even when it's 0 outside. The expansion and contraction that the temperature change causes is resulting in an open somewhere. When it's not working, check to make sure your amp is on. Then check your speaker leads. Something is not making contact during this time.
Beaver1992
Boom Boom Boom
Beaver1992
NC
Stalin-ohaulic
