nightshades 18s with 3500 rms on each
well how did you build them and can you i get recones off you with the new v2 parts im thinkin dual 1s
The v.2 coil will fit in the gap -- the spiders and cone are already the same as the v.2 -- the other v.2 differences are in the motor.
So... in short, you can get v.2 parts for it. The coil for the v.2 is almost 50% longer so does offer more thermal power handling.
i wish i would have got dual 1s so i could run each saz4500d at .25 on 16 v i would have seen more power but o well im thinkin after box rise i will see more realisticly 2750 rms each
i have horrible rise with everything i put in the truck with 2 saz3500s at .6 i only got 2000 rms out of each thats why i was running one a .3 and getting 3600 rms
i have 544 amp hours of batts and at 18.4 thats can keep up with 8007 watts if amps running 80% effieant with alts putting out 600 amps at 18.4 volts i should be able to run 10 to 11 k daily and if they were dual 1s 14k plus on burps
gtbike900
1loudyukonxl
gtbike900
ohio
hrtbrk1
