Sold NIB (4) Soundstream XXX-18's
Farmacist
Soundstream Elite
So I'm switching to a different size woofer...never really got to use these. All are in perfect condition, they've only seen power ONCE in this video here in mike singers wagon.(they were only put in for the show.)
XXX-18 WOOFER FEATURES
• Hardwired OFC 10ga. Copper Wire Leads
• Non-Pressed UV Coated Paper
• Flared Machined Pole Piece
• Chrome Top & Bottom Plates
• Die-Cast Aluminum Basket
• Aluminum Voice Coil Former
• Copper Clad Aluminum Voice Coil
• UV Coated Foam Surround
• Dual NOMEX Spiders
• Suspension Integrated Tinsel Leads
T/S Specs XXX-18
Fs (hz) 22.29
Qms 5.866
Vas (ft.3) 5.504
Cms (mm/n) 0.119
Mms (g) 430.2
Rms (kg/s) 10.23
Xmax (mm) 30.00
Xmech (mm) 40.00
Dia (in2)13.77
Sd (in2)149.10
Vd (ft.3) 0.136
Qes 0.191
Re (Ohm) 1.20
Z (Ohm) 1.2
BL (Gauss) 19.47
Pe (watts) 10000
Qts 0.185
NO .875
1w/1m SPL (dB) 91.40
2.8v SPL (dB) 99.81
VC Dia. (in) 4.0
Impedance (Ohm) QVC 1.2
They all still have their new warranty
Price - $475 each + shipping (weighs 120lbs in crate)
NO TRADES
I'll be using Uship.com, which will insure that the shipping is the lowest price possible (it's a site where companies will actually bid on your order to ship it, except the price drops in the bids instead of raises)
they will be shipped in their stock crates.
What size enclosure/tuning would you recommend for one of these? Very interested, since I have to go with a smaller setup, and a single monster 18 would probably still keep me loud
How many are left and any trades.
All 4 are still available.
2 are available right now, the other 2 are at another house in ohio, I have to go and pick them up.
The usual spec is like 5-6 cubes per sub, doesnt need more than 1000 watts to really get moving. Best sq out of an 18 I've ever heard.
ohio i go up there at least once a month any trades my good buddy i could pick these up from ohio i drive from louisville to norwalk ohio.
Is the amp for sale as well?PM me..
Edit:
Will two of these outperform two HCCA 15s?
If they were all given the same power?
no amp is not for sale.
I would definitely say that these would outpreform HCCA's , more cone area and theyre really efficient 18's
I would need to spend a bajillion dollars on amps for these woofers, and then another billion on electrical, wouldn't I?
not really, but they are what, quad coil 1.2 ohm coils... so you will need one large 1 ohm powerful amp or two amps that you could strap up @ ~2 ohm total or 1ish ohm each.
Farmacist
Soundstream Elite
Farmacist
Detroit, MI
subzero
