New XXX
Dan.
Ok i see the XXX has created many a arguement on the forum. But does anyone actually have the TS parameters? I dont want a debate as to how good it is or which is the best sub, just if someone has the TS parameters please post.... thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
XXX Series
12”
Electrical Q Value -Qes: 0.460
Mechanical Q Value -Qms: 3.290
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
thanks very much //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif dont suppose you have the specs for the 15's too?
Dan.
Dan.
peterborough uk
Dan.
