New RE MX Pictures
I'm assuming the woofer needs to be that deep to ahve enough clearance for the 40mm of xmax it has or whatever the # is.
MX Series
12”
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency - SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm per coil
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
noob
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
83 db efficiency? better have some power for it....
MUST SEE VIDEO!!
Oh and in the video i wanna see some of this...:boobies: and this too....//content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif
your x-max figure is off, as pointed out, lol..butm youre correct..for something to move as much as say, the new xxx..the coil(s) have to have somewhere to travel..which is why the xxx has the big **** looking thing on the *** end...i havent taken one off..but, im 99% sure the coil comes right through the back plate.
LMAO //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
//content.invisioncic.com/y282845/emoticons/offtopic.gif.470a8b0541c72322a0037f48a8237473.gif hey where are you in michigan?? i have a house on lake michigan near gran rapids i believe...the water is so cold..make nipples hard long time
90accordman
90accordman
Fresno, CA
90accordman
