new question! about RCA cables...
jaygeorge1979
I am talking about the red and white part of the RCA cable things (the audio parts)....what exactly is happening in these cables? i beleive it is stereo sound...one is left channel, one is right channel....is this correct? the reason i am asking is that i am trying to figure out how i am gonna hook up my DCX when i finally get it...it has enough outputs, but the stereo i am using has one pair of RCA audio inputs...if i can use one (say, the left channel) for midrange testing and the other (say, the right channel) for a tweeter testing, i can test em both at the same time to see which go together well...it wouldnt be stereo sound, but it would be two channels....am i even close to being right?
Yes
What exactly are you trying to do?
I told you how you will do it, remember? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You need to digest the data I send to you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
DCX is female XLR input, male XLR output.
Pic;
http://www.rcrowley.com/ComClone/images/Bottom.JPG
The one with holes is female, the other one with prongs is male. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You need a RCA {male end} to XLR male cable for sending a signal from
your 'RCA' source to DCX input.
Pic of XLR male end.
http://www.tonycolter.com/photos/potd/potd-20030429.jpg
For DCX output, you need a female XLR to 'whatever' cable.
female XLR looks like this;
http://www.coutant.org/a3f2.jpg
So.. if you have a proamp, you need a XLR [female] to XLR [male] cable
when using the DCX output. If you use a home amp with RCA input,
you need XLR [female] to RCA [male] cable.
Since the DCX output is a 'strong' signal you may not get the best signal to
noise ratio as home amplfiers have 'more gain', so you can cheat and reduce
output gain by 6dB if you do a 'trick' to the XLR to RCA output cable.
You can DIY these cables if you are skilled in soldering or you can buy
these adapter cables.
I don't know if the make the -6dB XLR to RCA cable.
If you want to DIY cables;
http://www.caraudioforum.com/vbb3/showthread.php?t=220559&highlight=cables
Once you get past the interconnect issue, the rest should be easy. If you never used XLR before,
it will be confusing. Take your time to digest the data. XLR in proaudio is a balanced interconnect,
home audio is unbalanced.
Who, what, why on this subject found here;
http://www.rane.com/note151.html
i understand what ur saying thy, but my question is about that output cable...i want to be able to run two drivers (mid and tweet) at the same time...BUT when i run output to a cable that converts XLR into 1/4", then i get an adaptor to go from 1/4" -- > RCA, there will be TWO RCA cables for that ONE channell...well i only have one pair of inputs...now, when i run a DIFFERENT output from the DCX to another pair of RCAs i will have 4 RCA males going into a single pair of RCA inputs...even if i buy splitters it will still send BOTH his/lows to both left and right, which means the crossover setup would be inefficient...what i am thinking is to use only ONE male RCA for each of the outputs from the DCX (that is, take one of the midrange level output and one from the higher freq output and put them intot he input)...wouldnt this put mids to one amp channel and highs to the other amp channel>?
The DCX as six outputs.
If you want to test one midrange and one tweeter, then you will use 2 DCX
outputs, one for midrange, one for tweeter, each output has it's own seperate
cable, one signal only per cable.
Why do you want to -> XLR to 1/4" to RCA ?
Why not -> XLR to RCA ? This is one cable and no extra adapter.
One XLR to RCA cable per DCX output is what you need.
If you DIY the cable, you can make a switch to include the 6dB output signal
attenuation.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The special XLR to RCA cable I made with the 6dB attenuation switch.
http://home.pacbell.net/lordpk/cables/Belden_8760_Cable/16.jpg
Normally, XLR pin 1 is also connected to pin 3 in a XLR to RCA cable.
If you want attenuation you disconnect pin 3 and leave it open.
DIY XLR Output to RCA with -6dB output gain
XLR Pin 1 = Shield ground => RCA ground
XLR Pin 2 = Positive balanced signal => RCA hot {signal}
XLR Pin 3 = Negative balanced signal = don't connect
I soldered a wire from pin 1 to the switch, from pin 3 to the switch. Now I
can toggle pin 3 open or shorted to pin 1.
/simple
even if i go from XLR to RCA there are still 4 total male RCA pieces and only 2 female RCA inputs...i think since each RCA cable is either left or right, i will hook the RED wire from each output that i use (one for mids one for highs) into an input RCA hole...this will be mono sound for each the mid and the tweeter, seeing as the left with be for the mid and the right will be for the tweeter...this will allow the amp to power each channel seperately considering whatever filter i have created from the actice crossover...NOW if thats all right...all i need to figure out is this attenuation hoopla...i dont want to build my own cables...that just seems like a whole other ball game...if possible, i would like to buy some XLR --> RCA cables and maybe mod them myself? is that possible?
To test one midrange and one tweeter keeping synergy, you should do this;
Input
Source left channel {RCA} -> DCX input [RCA male to XLR male].
Output
DCX output #3 -> XLR female to RCA male -> amplifier channel right [tweeter]
DCX output #2 -> XLR female to RCA male -> amplifier channel left [midrange]
If you have a 3rd amp channel and want to test a woofer;
DCX output #1 -> XLR female to RCA male -> amplifier channel 3rd [woofer]
Default configuration on the DCX is;
Output 1 - woofer
Output 2 - midrange
Output 3 - tweeter
Output 4 - woofer
Output 5 - midrange
Output 6 - tweeter
You can change this.
XLR to RCA cables;
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=4201
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=FetchChildren&Q=&ci=1667
I'm sure if you look hard you can find a better deal.
You can use a regular cable for now and if you have too much gain, DIY a cable
later. Mod a cable? If they connect that pin 1 to 3 at the connector side you have
to get in there to disconnect it, will this be easy to do or just make a cable?
DIY cables is simple;
See pics;
View pics in number sequence for step by step instruction;
Read the DIY cable guide I wrote on that CAF thread.
You can get some good Belden 8760 cable cheap.
thy, you said i can use a regular cable and if i have too much gain, then i can try DIY...what do you mean by too much gain? how will i kno?
in the event that i do, is there any chance i can slide you a little cash to make em for me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ?
Home audio amps usually have fixed gain and compared to pro audio world, the gain
will be on the high side. Pro audio amplifier have adjustable gain knobs and you
can adjust gain as needed. An amplifier with higher gain will create more audible hiss. Ideally you want to adjust the gain structure of the whole system for best
low noise.
In my case, my DCX drives both, one home amp, one pro amp. My proamp is
set about 1/3 gain, but my home amplifier is higher in gain driving tweeters, therefore the gain structure isn't optimum to keep the hiss low because the DCX
is driving a higher voltage into that amp. I do the 'trick' to reduce the signal into
the home amp. There is another way to reduce gain using resistors.
If I have time, I may be able to make cables. Later, if you have problems.
i still cant figure out what is the diff between balanced and not balanced...
Start here;
http://www.allaboutcircuits.com/vol_3/chpt_8/2.html
Learn what 'single ended input' is vs. 'differential input'. Differential is akin to balanced. A balanced setup is differential but a differential input doesn't guarantee that it's balanced.
Consumer audio is single ended input using a RCA cable. The generic RCA cable
has one wire to carry the signal and a grounded braided shield as the return path. Single ended meaning 'one input'. Some higher end home audio uses balanced or differential. All pro audio is balanced.
Balanced or differential needs 3 wires, two for signal, one for ground.
The signal is non-inverting and inverting that feeds into the amplifier and this
signal comes from the source, plus ground.
In proaudio they use [differential] balanced inputs to reduce noise induced in
long cable runs as differential inputs only amplify the difference between
input 1 and input 2 so any common noise on input 1 and input 2 will be rejected,
the amount of rejection is referred to as CMRR.
Pro audio also uses higher voltage preamp signal to raise the noise floor too, plus
balanced inputs, it kills any noises picked up by cabling.
To get off topic, you also have high speed digital electronics that have LVDS
inputs/outputs to get higher speed operation of the chip. 'Low Voltage Differential' Signaling;
http://www.webopedia.com/TERM/L/LVDS.html
There is alot of differential stuff in the electronics world, you just don't see it.
jaygeorge1979
jaygeorge1979
Corpus Christi
thylantyr
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
