You odviously aren't loudJust seems like screwing 2x4s or whatever they are together is a waste. Usually you seperate them or use a big sheet of plywood or something else for a wall or whatever.
I was talking to the guy that made the comment not you...So you changed plans again then huh?You still going with the one big amp then too or did that change as well?ditto! for 2 18s
no this is a temp setup for now unless im happy with how it performs. im using the mm4000.1 i had up for sale and the 2 adassa 18s but i might switch them out to nightshade 18s.I was talking to the guy that made the comment not you...So you changed plans again then huh?You still going with the one big amp then too or did that change as well?
