Orion XTR Pro 10'' d2
These woofers are brand new! With og packing, hex screws
They are 500watt rms each
D2 ohms
Copper Wound Voice Coil on Aluminum Former
Custom Cast Aluminum Frame
Custom Terminals
Symmetrical Tuned Long-Throw Surround
Custom Trim Ring
Tinsel Leads Stitched and Looped Across Spider
Tri-Cooling System
Fs (free-air resonance, Hz) 28.0
Vas (equivalent compliance, cu. ft.) 0.681
Qts (total driver Q) 0.44
Sensitivity 81.3dB
Pe (continuous power handling, watts) 500
Peak Power Handling (music, watts) 1000
Mounting Hole Diameter (Inches) 9
Mounting Depth (Inches) 5.9
$105 shipped or $210 for both shipped
List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).
D2 ohms
Custom Terminals
Custom Trim Ring
Tri-Cooling System
Sensitivity 81.3dB
