Sold New FS Thread
Hintzyboy
Sparks mean its working!
OK Guys, I think this is my third FS thread for this equipment. I got tired of bumping the other ones and I actually managed to sell a couple things;) . I'm pretty sure this is everything, but I'll add stuff if I find it.
OK Here Goes. All prices are OBO. PM me with your zip for shipped prices. More Pics available on request.
Thanks.
Aaron
BNIB Eclipse SW8102 DVC Subwoofer. $125 plus sh.
Power Handling: 650W rms, 2000W peak
Solid Aluminum Cone
1" Wide Santoprene Surround
3", 4 layer Aluminum Voice Coils
Dual Mirror Image Spider
Integral Woven-In Leads
BNIB Eclipse EA2212 2-Ch. Amp $75 plus sh.
Output Power:
70W x 2 Ch @ 2 ohms
50W x 2 Ch @ 4 ohms
140W x 1 Ch @ 4 ohms bridged
BNIB Stinge SWCKH44 3/4 Amp Full System Wiring Kit $200 plus sh.
Includes:
-Esclusive 1.2 Farad Stinger Capacitor with 4-Digit LED Voltage Display
-Four-gang, HPM Digital AGU fused distribution block
-Water resistant 4 gauge ANL fuse block with voltage gauge
-Two 16ft twisted pair RCA's
-Two Deluxe multi-output battery terminals
-Dual power-ground distribution block
-Multi-output distribution block
-22ft 4-gauge translucent blue power wire
-6ft 4-gauge translucent silver ground wire
-12ft 8-gauge translucent blue power wire
-12ft 8-gauge translucent silver ground wire
-6ft 12-gauge translucent blue speaker wire
-50ft 16-gauge translucent blue speaker wire
-Two position ring terminal in molded translucent case
-Four 60-amp AGU fuses
-150-amp ANL fuse
-Two grounding terminals
-All necessary hardware
-22ft of remote turn-on wire
Used Memphis ST2004 4-Ch. Amp $100 shipped
7-8/10 Cosmetically, 10/10 Mechanically
50w x 4 at 4
75w x 4 at 2
150w x 2 at 4 bridged
I believe the slopes are set at 18db/octave, other than that I havent found any info about it at all. I bought it a year ago with the purpose of going active, but ever really got around to it.
If you didnt catch the rest of the info on ROE...Alpine 3672 crossover. VERY rare never even seen one for sale. Made back in the Golden days of Alpine in Japan unlike todays crap. Does three way active front, two way rear, sub out, and has individual gains and phase switches for each set of channels. Parallel inputs. Has on scratch across face that doesnt effect performance.
You can set the fronts to do three way, two way, or one way and the rear two or one. The only down fall is the crossover points are dependent of the others.
For the front, they are all high pass crossovers, so whatever you set your midbass, the low pass depends on what you set your high pass on the midrange and so on...not to big of a deal just takes away a little tweeking like if you want to add a larger gap or overlap the two speakers...
For the subwoofer, its a lowpass ranging from 50-120HZ, the Front midbass ranges from 10HZ-120HZ high pass, the midrange varies from 200HZ-2KHZ and the tweet ranges from 3khz-10khz...
For the rear the Mid woofer ranges from 50-800HZ and the tweet 3khz-10khz...
Whew...hope that helps. i was trying to take a picture but the flash wasnt really working out for me...
Edit: i lied, you can see the crossover points clearer than I thought. You can also see the scratch....
Update:
-Eclipse sub gone to Fast1One. Just waiting for the X-over to get here :yum:
-Lots of interest on the Memphis ST2004, but no real bites just yet. First one to pay takes it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hintzyboy
Hintzyboy
Baraboo, WI
Hintzyboy
