:facepalm:meh still hifonics lo,l until they start "under rating" there amps im good, still some have good luck with them
so an amp has to be under-rated to be good ?meh still hifonics lo,l until they start "under rating" there amps im good, still some have good luck with them
I know you praise Hifonics, but sorry, they do not put out rated power.:facepalm:
ive been on the forum for the last 20 or so minutes, and the level of idiocy i have seen is painful.
Im logging off.
//content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gifI know you praise Hifonics, but sorry, they do not put out rated power.
This. When they start rating amps at 12v I'll consider buying one again.meh still hifonics lo,l until they start "under rating" there amps im good, still some have good luck with them
I edited my post. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gif
How do you know this? Have you personally bench tested these brand new amplifiers?
I don't care if they're over rated- they still put out more reliable power per dollar than most other amps, even if it is below rated. Also, the Brutus amps from 08 and up have been pretty spot-on with the ratings.
I follow you. And I'm not arguing that they are bad amps! But rate them for 1000W if that is the power they output...Hifonics BXi1210D = $170 shipped
Audioque 1200D = $250 shipped
Now, lets assume that the Hifonics really does 1000w. That's 17 cents per watt.
The Audioque is 21 cents per watt.
Also, there are what... like four companies that still rate at 12v? Don't get me wrong, I'm a fan of rating at 12 volts because rating at 14 volts is somewhat deceptive.But even your beloved AQ1200D is rated at 14v.
