Soundstream MPQ-4XO w/Crossover
Brand new, used for one month. Great piece. I replaced a Pyle parametric equalizer with this and this is 110% better. Boost/cut frequencies and for each band and you can adjust the center frequency bandwidth with a needlenose screwdriver.
I'm selling because I'm looking to get more bands (my 6x9 Infinitys have too much top end). I bought it new at ebay for $90 total. Retails for $80+. I have to get some photos and borrow a digital camera this weekend. Shipping is no more than $5 anywhere. Guaranteed not DOA and 20-day money back guarantee if the unit does not work properly. Includes all hardware (brackets, etc.)
I compared this with other 4-band parametrics like Phoenix Gold and Audiobahn and this had better specs. Asking $47.50
http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=mpq-4xo
* Master volume control with up to 7 volts RMS of output
* Front/rear fader control
* Four band parametric equalizer with 18dB boost per Cut.
* Variable bandwidth for each band
* Low noise Bi-Fet op-amp design yields minimum distortion
* 30V bi-polar switching power supply
* Subwoofer output and level control
* Subwoofer frequencies adjustable 50Hz-250Hz
* Dual input selector
* Universal half-Din chassis for ease of installation
* Gold-plated RCA input/output connectors
* 20dB headroom eliminates signal overload
* 4 band parametric range: Sub 20-70Hz/Low 150-400Hz/Mid 1.5-4 KHz/HI 4-20 KHz
* Subwoofer Crossover: 50-250 KHz
* Boost/Cut: 18dB
* S/N Ratio: >110dB Ref 1V Input
* Frequency Response: 10Hz-15 KHz, + / -1dB
* Stereo Separation: 82dB/1KHz
* Maximum Output Voltage: 7V RMS
* THD:
* Headroom: >20dB
* Input Impedance: >50k Ohm
* Output Impedance:
* Boost/Cut: 18dB
* THD:
* Headroom: >20dB
* Output Impedance:
