need suggestion which preamp is good???
  • 2
chelopr
i need a preamp whic one is good???
In think my head unit (clarion db425) don't have enought power to move my rockford 250.a2, then i need a preamp with 5-7v output power. i need suggestion wich preamp is good quality and very good price. any sugg...!!!!???
head clarion
crossover coustic xm3
sub amp rocford 250.a2
subs 2-12 audiobahn dc
eq sentrek 7-band
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Phoenix gold makes a nice little 8 volt line amp, the PLD-1, It's only $99. Audio control is known for making high quality pre amps, line amps, and eqs. but there not as cheap. Make sure you get a good one otherwise it might make your system sound worse.
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
6
61
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
179
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
133
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
476
chelopr
chelopr
San Juan, pr
indosia
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
