Need some ideas for 2 15"L7
  • 2
What kind of vehicle ? How much space are you going to sacrifice for the enclosure ? What kind of amp ? And last but not least what kind of music do you listen to, what kind of sound are you after ? Let me know and we'll see what we can do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I own a 2002 chevy suburban. Im debatin whether to take out the third row of seats. IM also debatin the amp. it would be nice if u give me a suggestion on that too. i listen to rap rock alternative,etc....(everything except country)
Thanks
Allrighty, well You could put alot of power to those subs. At least a 1000w each. There are several amps that would be ideal. The directed 1100d, phoenix gold has a tantrum 1000d I do believe, The fosgate bd1000.1, The kicker zr1000 would be a good choice if you can find one. There are alot out there. What kind of money are you looking to spend ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would be willing to spend up to 600 but if i can help id want a go a bit lower
Should i be gettin a mono amp or a 2 channel amp...whats better and what would be the difference when all is said and done...thanx
Originally posted by gdatw019 I would be willing to spend up to 600 but if i can help id want a go a bit lower
The difference is you could possibly use a 2 chanel amp for something else besides subs later on down the road. A mono amp is more than likely going to be a class D nowadays. And it's meant for subs only. I would get a Class D mono amp. They are usually way more efficient than A/B amps.
As for the box. A 6cuft common chamber slot ported tuned to 35hz would fit the bill pretty d@mn well //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I use 3/4" MDF for all boxes. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
170
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
470
gdatw019
gdatw019
fayetteville, nc
ramos
    May 18, 2024
    May 18, 2024
