Need help (could I install on my car ?)
begreen
usa
Hello everyone,
I'm glad that I've found such great forum.
Guys, I hope that you can help me...
In order to save some money on fuel, I'm planing to install the ethanol e85 kit on my 2004 Dodge Ram 1500 and run it on ethanol,
One of my friend uses the kit from this French manufacturer (Kit Ethanol E85 EcoFuelBox , Kit E85, Kit Flex Fuel, Kit Bioethanol, Boitier Bioethanol, Boitier Ethanol, Flexy Fuel Kit) but the problem is they have 4 models and 6 type of connectors, and I'm not sure which kit fill fit my Dodge. Can someone tell me, what type of connector do I need for my Dodge Ram ?
Regards,
im a mechanic and just a little info.eth.will cause you miles per gal to go down quite a bit because the BTUs are not near as efficent as gasoline.why would you want to spend the money to convert to that?eth,is also very corrosive unless vehicle is made for it.ones made for it use seals,all fuel lines,fuel pump ect.i have seen fuel lines get very soft and gummy from the use of to much eth.
begreen
begreen
usa
bluelake08
