need 12" w/ 6" mounting depth
FalconXtreme
Wheres my pants?????
y0 i need two budget 12" subs with around a 6" or less mounting depth. each will be in a .9 cube sealed enclosure. i plan to throw each sub 300wrms. amp is dependent on sub. so far i think i want some eD Ks but i wanna see what else is out there.
I've been told to expect them to be about $100 less than the old ones... I'm not sure what the old ones were though.
My guess is they will be $200 - $250 each.
get at me if u want the m3s I'm getting a mojo and no longer need these....if u got a nice set of components and amp we can work sumtin
224
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
197
519
FalconXtreme
FalconXtreme
bay area, ca
FalconXtreme
SPLBassJunkie
    May 21, 2024
    May 20, 2024
