My new SPL enclosure enjoy. dedicated to req, jmac, supa, acid, squeek etc.
AznRevlAzn
otaku
Here it is. Tuned to a high 40Hz. I was thinking 60 but I though that it would be totally unnecessary and completely unlogical //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
No i will not give the specs out.
Yes there is an insane amount of bracing
Yes i have sweat out 12 ounces of sweat from working at 12 in the humid heat to 6 in the Humid heat.
Yes my white ralph lauren shirt turned pink while i was working, Don't ask how.
I almost destroyed my Morpheus SunGlasses by Blinde Design, don't ask how.
The box is ungodly heavy
Yes i will carpet it
Yes there are terminal plugs in it
Yes it will be bolted down to my cars frame
Yes i used T-nuts.
The Sub fit snug into the mounting hole thanks to a nifty new router tool i got //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Now that i have avoided all questions so i can never return to this thread... ...the pics //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
$5 says you lost alot putting that bracing in there...another $5 for the bend in the port....and another $5 with that foam crap
yes i did lose quite a bit of room //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif almost half a cube
Yes idk why you wont give out dimensions...
Yes threaded rod>wood bracing
Looks great though.
i actually did think about the threaded bracing but i was worrying that the threads would eventually give way so i opted for the wood bracing instead. I had a bit left so i didn;t feel like wasting it anyways.
What inhuman meant by his comment is that you are losing SPL, not space.
All of the things you did to your "SPL" box actually made it a WORSE SPL box.
exactly...and ill add that if you do carpet it, you'll loose more...just look at the amount of gap you have between the brace and the port opening.
AznRevlAzn
otaku
AznRevlAzn
TriState Area
AznRevlAzn
