I currently have the Pioneer 800PRS installed and I just picked up a 3sixty.2. I was wondering what the best way to run my 3way + sub would be. Should I run the midbass from the 800prs front outs (because it's bandpassable) and send the rear and sub outs to the 3sixty.2 to run the midrange, tweets, and subs from the 3sixty.2 unit?
Also, if I'm running the sub and rear outs to the 3sixty.2, how do I defeat the Pioneer processing to only utilize the 3sixty.2 processing? Should I just let through as much of the frequencies as possible? For example, the sub outs go up to 250hz, should I set it that high so I can let through as much as possible and also do the same thing with the rear outputs which go down to 1.25khz, so I would be sending the rest above that?
Any help or advice would be appreciated and if you've ran a similar setup, I'd love to hear any comments you may have. Thanks
