Much difference between Arc and Sundown?
syk69
I plan on getting some Morel Tempo 6 component speakers in my 350z. Going to run at 4 ohms either Sundown SAX 125.2 or the Arc Audio KS 300.2. Will i hear a lot of difference between these 2? Or should I just go with the cheaper amp? The Sundown does 125 x 2 and the Arc Audio does 180 x 2. Thanks!
You can't go wrong with either. I prefer Sundowns, obviously, but ARC makes nice stuff too. Whatever you can afford would be a good choice.
is Arc Audio worth the price difference for how much it changes the sound?
I had a very knowledgeable friend listen/tune my truck and it was the first time he had heard Sundown amps, and told me it would be a waste of my money to upgrade them unless I went with something along the lines of Arc SE's, Zapco Competition series or Tru and so on.
I am very happy with my Sundown amps and will gladly run them again in the future.
Well amps do not really "change" sound. They just either do a good job or a bad job. The headunit is what the source input is. IMO, besides the fact that I'm a dealer, I think the extra money for the ARC would just give you the satisfaction of running a high dollar amp with little to no gain of sound quality.
I have used both and can honestly say they sound great, I would have to lean toward the Arc if used for serious SQ. that means the best HU like a DRZ 9855 , McIntosh, Rockford 8240/50. and the best speakers like Hybrid Audio, Dynaudio, Focal, etc.
on normal Hu like 9887 ( nice BTW ) and Sundown, or Arc KS series I could not tell much difference. Not much difference on the output either.
So either one would be great. Just say away from Maxxisonics Junk. :p
All amps sound the same. Car audio manufacturers are in business because people are foolish enough to believe that they hear sound differences between amps. People swap out and buy different amps believing when one will sound better than the other. It's better to get an amp that is built solidly, does it's rated power, and looks the way you want it to. Like the earlier post said, its better to focus on the speakers and head unit because that's where the sound comes from. All amps do is amplify the sound. Because of the difference in wattage, one amp may sound a little louder but that is it.
you must be new to the world of car audio, welcome!
Since 1989, i tell you one thing, I will keep the same high quality amps, buy high quality speakers and a high quality head unit and save my money. I have heard them all and they all sound the same if you set the gains correctly. Reference the Richard Clark test.
I will no longer go out and waste my money believing for a small percentage difference one amp will sound tremendously better than the other. That is an easy way to throw money down the toilet.
Clean sounds, you are retarded. There is more than one way to convert an analog 10khz signal to high component 120khz to a low component 10khz signal. When you able to understand that, then open your yap.
syk69
syk69
florida
DEdwards
