Up for sale is a MTX Thunder 942 2 channel Amp. I bought this amp for $289+ship about 2 weeks ago for my beater car. However, the amp seems to have outlast the car since it just crapped out. Amp was only used for about 4-6 hours max. It was bought Authorized so the warranty will still apply. The amp still looks brand new and comes with everything, original box, MTX decal and birthsheet. Specs and pics are below:
• RMS Power measured at 12.5 Volts DC:
175 Watts x 2 into a 4 Ohm load with less than 0.1% Thd+N
350 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
700 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
• Dynamic Power measured at 14.4 Volts DC:
235 Watts x 2 into a 4 Ohm load
470 Watts x 2 into a 2 Ohm load
940 Watts bridged into a 4 Ohm load
• Signal to Noise Ratio: ≥110dB A-Weighted
• Damping Factor: >200
• Frequency Response: 20Hz-20kHz ± 0.25dB
• Maximum Input: 8Vrms
• Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
• Crossover: Variable 40Hz to 200Hz, 12dB/Octave Stereo
High Pass, 24dB/Octave Mono Low Pass, or Full Range
• Dimensions: 17.8" x 9.75" x 2.1" (45.3cm x 24.8cm x 5.3cm)
BIRTH SHEET: 854 at 4 ohms bridged at 12.5 volts.
I would say that a clean 1100- 1200 watts can be expected at 14.4.
Once again, amp is in excellent condition and can pass as brand new w/o a doubt. Theres one small scuff on the top which isnt deep and possilbly can be rubbed out. These are quality amps..im sure you will be happy.
