I can get both of these amps for about the same price. Which would be the better choice on quality and power?
Orion 2500D Specs:
Class D technology for cool, stable operation
1 Ohm stable - 2,500W RMS into 1 Ohm!
Polished gunmetal heatsink with etched Orion logo
Mil-Spec double-sided circuit boards
Massive power supply with oversized torroid transformers
Paralleled internal power bus bars
Complementary bipolar output stage transistors
Variable 30-250 Hz low-pass crossover
INTELLi Q Bass processing
Variable 0-10 dB INTELLi Bass equalization
Variable 10-150 Hz subsonic filter
Satin finish direct-wire power and ground connections
Proprietary Copy/Master feature for multi-amp systems
Selectable preamp outputs
Copy/Master switch for gain and crossover matching
Separate variable high-pass crossover for preamp outputs
Removable end caps
Full CEA-2006 compliant specifications
13.8V RMS power ratings - even more power into 14.4V!
Optional RGC-1 remote gain control
Requires external 200-amp fusing
Subwoofer Mono Amp SpecificationsAmplifier Type: Mono
RMS Power: 1200W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power:
Bridged RMS Power: 1700W x 1 @ 2 Ohms
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: LP
Bass Boost: 0-10 dB
Frequency Response: 20-250 Hz
Signal to Noise Ratio: 50 dB
Fuse Rating: n/a
MTX TA92001 Specs:
Thunder Super Amplifier
Prizm EFX: Selectable Lighting Color, or Pusate to Beat
Xtant Technologies Cooling: Thermal-Regulated, Turbo-Charged Intercooler
RMS Minimum Power Rating:
1000 Watts x 1 Channel @ 4 Ohms
2000 Watts x 1 Channel @ 2 Ohms
3000 Watts x 1 Channel @ 1 Ohm
Wired EBC Remote Subwoofer Bass Level Control Included
CEA-2006 Compliant
Strappable with Another TA92001
Power and Protection LEDs
Parametric Bass Control:
-12 - +12 dB Bass Control
Variable Bass Control Frequency: 30 - 80 Hz
Variable Bass Control Q: 0.5 - 4.0
Onboard Crossover: LP (40 - 200 Hz), Sub (20 - 50 Hz)
Phase Control: 0° / 180°
Semi Unregulated MOSFET Power Supply
High or Low-level Input
Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
0 Gauge Power Connectors with Built-In 4 Gauge Capacitor Terminals
Wired Bass Remote Control Included
Frequency Response: 20 Hz - 200 Hz
Dimensions: 24-11/16" L x 9-5/8" W x 2-1/2" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 1000 watts x 1 channel
RMS Power (2 ohms) 2000 watts x 1 channel
RMS Power (1 ohm) 3000 watts x 1 channel
Bridged RMS Power N/A
Peak Power Output 6000 watts x 1 channel
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged N/A
THD at Rated RMS Power 0.5%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 40 - 200 Hz
Subsonic Filter 20 - 50 Hz
Signal-to-Noise Ratio 65 dB
Channel Separation N/A
Bass Boost -12 - 12 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating N/A
Orion 2500D Specs:
Removable end caps
Preamp Outputs: yes
Bass Boost: 0-10 dB
Fuse Rating: n/a
MTX TA92001 Specs:
CEA-2006 Compliant
Amplifier Class D
Fan Cooled Yes
Fuse Rating N/A
