MTX TA7804 and MTX RT2001X on 5.25 Components
mr b
So I picked up a MTX RT2001X, and it simply out performs my expectations. It has to be about 20 years old and I can't believe how it sounds. So here is the question. Old school MTX was really good. How about not so old like the MTX TA7804? I am getting a great deal at $80.00 and it works and looks brand new. I am considering using it or the RT2100X for 2 sets of 5.25 component speakers (Old School MB Quartz made in Germany). Is the MTX 7804 or MTX 2100X going to be higher SQ? I also have an Alpine MRV-F340 with only 4 x 55 watts. I understand the THD is much lower on the Alpine but haven't used a lot of Alpine.
MTX TA7804 Specs
Thunder 4-channel Super Amplifier featuring patented class A/B output
100 watts RMS x 4 at 4 ohms, 200 watts x 4 at 2 ohms
400 watts RMS x 2 bridged output at 4 ohms, 800 watts x 1 front/rear summed output
Wired EBC Remote Subwoofer Bass Level Control Included
Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
Semi-unregulated MOSFET power supply
Overload and thermal protection
StreetWires connection terminals
Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
Bass boost at 40 Hz, 0~18 dB/octave variable
A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
Input (RCA connection): Low-level, hi-level w/Smart Engage
Input sensitivity: 100mV-1V/1V-10V switchable
CEA-2006 Compliant
Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
MTX RT2100X Specs
RMS Power (12.5 Volts DC):
• 50 watts x 2 into a 4 Ohm load with less than .1% THD
• 100 watts x 2 into a 2 Ohm load with less than 1% THD
• 200 watts bridged into a 4 Ohm load with less than 1% THD
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC:
• 85 watts x 2 into a 4 Ohm load
• 140 watts x 2 into a 2 Ohm load
• 280 watts bridged into a 4 Ohm load
Signal to Noise Ratio: 110dB A-Weighted
Damping Factor: >200
Bass Boost: Variable Centered at 40 Hz (0 to 18 dB)
Crossover: 80 Hz, 18 dB Low Pass
Frequency Response: 20-20,000 Hz ± .25dB
Dimensions: 7" x 9" x 2" (17.8cm x 22.8cm x 5cm)
Alpine MRV-F30 Specs
55 watts RMS x 4 at 4 ohms
65 watts RMS x 4 at 2 ohms
130 watts RMS x 2 in bridged mode
2-, 3-, or 4-channel output
Tri-Way capable
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
Bass Engine features:
variable 30-400 Hz high-pass/low-pass crossovers, 12 dB/octave
rear channels have a subsonic filter at 15 Hz
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
speaker- and preamp-level inputs
preamp outputs
oversized power and ground connections
gold-plated screw terminals
top mounted controls with cover
detachable front cover
blue power LED
10-3/8"W x 2-1/2"H x 12-3/8"D
So you own all three of these amps? Hook each one up and let your ears tell you what sounds the best. What sounds good to one person may sound like garbage to another. Just because people say that the alpine sounds the best doesn't mean that is going to be the case in your install .
I haven't picked up the TA7804 yet. I am getting what I think is a good deal at $80.00 but am slowly dealing with my audio addiction by trying to avoid buying another amp. I took your advice, the MTX sounds stronger if that makes sense, whereas the Alpine sounds warmer. I have no clue what to expect from the MTX TA7804 so I thought I would ask. It's a beast but I don't have any experience with that amp line.
mr b
mr b
Los Angeles
mr b
