I couldn't edit the other thread anymore, so I am redoing it with new prices. If a mod would please delete the first post, thanks.
First is an old and scratched 5 channel MTX. Cosmetically it has had way better days. It is missing 3 screws for the terminals. It still works 100% though. All channels power up fine. I am looking for $100 shipped OBO. Here are specs and pics.
Specifications
RMS Power measured at 12.5 Volts DC:Front & Rear:
25 watts x 2 into a 4 ohm load with less than 0.05% THD+N
50 watts x 2 into a 2 ohm load with less than 0.1% THD+N
100 watts bridged into a 4 ohm load with less than 0.1% THD+N
RMS Power measured at 12.5 Volts DC:Subwoofer
100 watts RMA into 4 Ohms with less than 0.3% Thd+N
200 watts RMS into 2 Ohms with less than 0.5% Thd+N
Dynamic Power* Front & Rear
65 watts x 2 into a 4 ohm load
125 watts x 2 into a 2 ohm load
250 watts bridged into a 4 ohm load
Dynamic Power* Subwoofer
150 watts x 1 into a 4 ohm load
300 watts x 1 into a 2 ohm load
Signal to Noise Ratio
> or = 100dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover (Front)
Variable 40Hz to 175Hz
12-18dB/Octave
HP Defeatable with 45X Frequency Multiplier
1.8k-7.9kHz
Crossover (Rear)
12-18dB/Octave
HP Defeatable
Crossover (Subwoofer)
18dB/Octave, LP
Dimensions
15" x 9" x 2" (38.1cm x 22.8cm x 5cm)
Next are Rockford Fosgate Silver 10" He2s. I don't have the rubber gasket. Never used it. I want $100 shipped OBO for these. They are RFP4210 and handle 400WRMS each. T/S sheet is at http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=Fz1FO*Qh&p_tbl=9&p_id=155&p_created=1056749392
Specifications
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover (Front)
12-18dB/Octave
1.8k-7.9kHz
Crossover (Rear)
12-18dB/Octave
HP Defeatable
18dB/Octave, LP
Dimensions
