130.00 shipped OBO
Summed Output - a line level summed out put of the right front/right rear and left front/left rear input signals. Use this to drive an external subwoofer amp.
Gold-Plated, differential high-level inputs.
Larger Output MOSFETS, for superior performance at sustained loads.
New, more flexible ISO-FEET mounting. This simplifies the installation process.
Specifications
RMS Power measured at 12.5 Volts DC: 37.5 watts x 4 into a 4 ohm load with less than 0.1% THD+N
75 watts x 4 into a 2 ohm load with less than 0.3% THD+N
150 watts bridged x 2 into a 4 ohm load with less than 0.3% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
90 watts x 4 into a 4 ohm load
165 watts x 4 into a 2 ohm load
325 watts bridged x 2 into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover
Variable 40Hz to 175Hz
12-18dB/Octave
HP or LP configurable
Dimensions
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4 Wide Including IsoFeet (36.2cm)
needs cleaned up a little, but in very good shape
Specifications
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover
12-18dB/Octave
Dimensions
