Mtx 81000d
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif wrong place
Actually, this is the "amplifier" section.
The mod takes off the low ohm load protection allowing you to run the amp in 1 ohm instead of 2 ohms. At the same time, this mod will make the amp run hotter than usual and is not recommended since you are taking off a factory protection. You take the risk of the amp going up in smoke.
my 1501d's power input came off of the board yesterday //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
shit hit's so hard it broke the solder //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
if you mod it, it's no longer "stable" IMO. you let the volts drop and you loose it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
if you run this at 1 ohm, you better have a ballsy electrical
words of the proffesional
thanks for the input guys. today at work i tried it with a one ohm load for about one solid hour at around 70% power and it did get hotter than it usually dose but held up just fine, this was with out any mods.
even at 2 ohms, it could be hell on the electrical so when it gets installed fianally i will use a 2nd battery with it.
-vic
thevic24
my silence is deadly...
thevic24
right behind you
thevic24
