Both amps only used for about 2 months and are in perfect condition.
Thunder 8302 - $150
Thunder 81000D - $250
Thunder 8302
• 2 Channel Amplifier
• Power 12.5V
• Rated Power (stereo): 75 W RMS x 2 @ 4 ohms, 2 X 150 WRMS @ 2 Ohms
• Briged Power 1 X 300 RMS 4 Ohm Mono
• Power 14.4V
• Rated Power (stereo): 120 W RMS x 2 @ 4 ohms, 2 X 212 WRMS @ 2 Ohms
• Briged Power 1 X 425 RMS 4 Ohm Mono
• Frequency Response: 10 Hz-30 KHz
• Crossover Hi/Low Pass 40-200Hz Variable
• Hi/Low/Full Range RCA outputs
• Dimensions: 11.5"L x 9.75"W x 2.1"H
Thunder 81000D
• Class D Mono Block Amplifier
• Power 12.5V
• Briged Power 1 X 500 RMS 4 Ohm
• Briged Power 1 X 1000 RMS 2 Ohm
• Power 14.4V
• RBriged Power 1 X 850 RMS 4 Ohm
• Crossover Low Pass 40-200Hz Variable
• Low Pass Output
• Electronic Bass Control
• Dimensions: 17.8"L x 9.75"W x 2.1"H
Thunder 8302 - $150
Thunder 8302
• Power 12.5V
• Power 14.4V
Thunder 81000D
• Power 12.5V
• Power 14.4V
• Low Pass Output
