Sold Mtx 251d / Re Re 10"
lvfive.o
Selling the amp and sub out of my truck, going with something a little bit bigger, stuff works good only thing you will need is a box. Sell them both for $100 shipped.
MTX 251D
RMS Power 14.4
2 Ohm Load 200 w x 1
4 Ohm Load100 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 250 w x 1
4 Ohm Load125 w x 1
Dimensions (with ISO Feet)
7.98" x 9.75" x 2.1"
20.3cm x 24.8cm x 5.3cm
RE Re Series 10"
Mounting Depth - 5”
Mounting Hole Diameter - 9.125”
Overall Diameter - 10.125”
Bolt Hole Circle - 9.75”
Motor Width - 4.875”
Motor Depth - 1.5”
Basket Depth - 3.5”
Displacement - .09 cu. ft.
Weight - 6.5 lbs.
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
lvfive.o
lvfive.o
Las Vegas
lvfive.o
