MTX 1501D vs MTX 81000D ? Memphis 16-MC1500D vs Memphis 16-ST1500D ?
Rookie_80
Whats the difference between two MTX amps and two Memphis amps.
1501d and 81000D have the same specs so does the ST1500d and 16-mc1500d.
They are alson in the same price range
I heard a lot of ppl saying they are pretty much the same amps.
But if they're the same, then why produce two different amps instead of one?
i'm 99% sure the 1501 and the 81000 are the same board. why produce 2 amps?? idk
true. Memphis 16-MC1500D and 16-ST1500D have the same board as well.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
With 2 1501Ds you would simply connect the positive speaker lead of 1 amp to the positive terminal of your voice coil. Then with the second amp have your phase switched 180 deg. and then connect the positive lead of the speaker output to the negative terminal of your voice coil. And whammo! you,ve got over 4K.
Thats reminds me. The other difference is that the 1501Ds have a phase switch where as the 81000Ds do not.
So to switch the 81000Ds you need an external X-over with a phase switch.
That is not exactly what i was referring too....
Rookie_80
Rookie_80
Houston,tx
Ed Lester
