rollerdj
Low End Master
So, my 02 nissan sentra spec-v started to get a little bit of a mis-fire in it when i first started up. it's got worse today with it finally pulling a code, being mis-fire cyl #4. so, seeing how i have 91k on this car, first thing that comes to mind is a tuneup. start to pull plugs out, and #2 is all but stuck in there. much tighter than the others, and as i try to loosen it, it started to make some odd noises. witch after hearing that, i stopped before doing any damage to the head. so, questions to you guys.
A) how best to get that bastard out without and damage to motor?
B) should i replace all the coil packs. this car has one per cyl right above the valve cover.
