you're retarded.mono-A prefix that means "one, only, single," as in monochromatic, having only one color. It is often found in chemical names where it means "containing just one" of the specified atom or group, as in carbon monoxide, which is carbon attached to a single oxygen atom.
opareyoualwaysretarded?
The Ap30001d is a DUAL monoblock, just like any that have two outputs. A mono amp has ONE output, usually with parallel terminals, like you stated.This question's been asked every few weeks for the past ~10 yrs.
There are a FEW mono's that are actually twin mono's in one chassis -- I think the Audiopipe ap30001d is one. Those actually do give you two channels of amplification. One of HF's giant ones is set up the same.
Other than those few they're all just parallel outputs.
From what I have seen the vast majority of amps over, I don't know, 500w or so? have two parallel outputs.
I know what a monoblock amplifier is..............and can tell the difference in a speaker distrobution block and a separate speaker output terminal //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifyou're retarded.
I laugheda Dual monoblock amplifier......
Dual XPA 600-Watt 1-Channel Monoblock Amplifier XPA6100 - eBay (item 310274675303 end time Dec-26-10 21:26:28 PST)
