Mmats PRO SQ4160 4x160 4 channel
gentlejax
Item(s) for Sale:sq4160
Item(s) Description/Condition:some scratches. internally magnificent.
the most outputs I have seen in any amp and they are big. garantee this does more than 160 x 4
SPECIFICATIONS
SQ4160
POWER @ 13.8 Volts:
RMS @ 4 ohms stereo 4 X 160
RMS @ 2 ohms stereo 4 X 175
RMS @ 4 ohms mono 2 X 350
Idle Current: 1.5 amps
Signal to Noise Ratio A-Wtd:
Total Harmonic Distortion: 0.04%
Channel Separation:
Input Sensitivity: 150mV-5V
Slew Rate: 15V/Usec
Fuse Rating: 60 amp
Dimensions:
Height: 2.25”
Width: 11.375”
Length: 19.375
General Information:
Frequency Response:
Lowpass Filter: Variable 24db, 60 to 360Hz
Crossover: Lp / Hp / Off
Battery Connetors: 4 Gauge
Speaker Connectors: 8 Gauge
Price:$325
scratches on top left corner and bottom right corner appear to be past the clear. most of the rest are not as bad and pics make it look worse than it is when in your hands. I have been meaning to try to clean it a little.
I wasnt too concerned about that , more concerned with the power and quality of the build. If I kept it I might have it blasted clean or powdercoated.
gentlejax
gentlejax
Bossier City, La.
aztec
