Item(s) for Sale: Minty Taramp HD5000 1ohm version.
Item(s) Description/Condition: In excellent condition, I take great care of my equipment, ask any of my past buyers. Taramp's HD-5000 1 ohm High power Mono Car Audio amplifier - 5,000w RMS @ 12.6 VDC - High Definition and Maximum Performance – These high power line of amplifiers from Brazil bring you the best in engineering and power for your extreme car audio installations. Taramp’s has a well-deserved reputation for building high-quality, high-power mobile audio products. The HD Series amps are some of the best-selling models, with variable high and low pass filters (crossovers), extreme durability, while delivering more reliable performance at standard car voltage on the market today.
Number of Channels - 01
Output power @ 13.8 VDC - 1 OHMS - 5997W RMS
Output power @ 13.8 VDC - 2 OHMS - 4000W RMS
Output power @ 13.8 VDC - 4 OHMS - 2398W RMS
Output power @ 12.6 VDC - 1 OHMS - 5000W RMS
Output power @ 12.6 VDC - 2 OHMS - 3335W RMS
Output power @ 12.6 VDC - 4 OHMS - 2000W RMS
Input Sensitivity: 250mV @ (-9.78 dBm)
Total Harmonic Distortion (THD): 0.3%
Signal / Noise Ratio: >95dB
Damping Factor: 400
Frequency Response: 5Hz a 15KHz
Crossover:
H.P.F (High Pass Filter): 5Hz to 50Hz (-12dB/octave) Variable
L.P.F (Low Pass Filter): 50Hz to 15KHz (-12dB/octave) Variable
Input Impedance: 18K OHMS
Protection System: Short into Output / power Supply High / Low
Minimum Supply Voltage: 10.5VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 2.60 Amp.
Musical Maximum Consumption @ 12.6VDC: 274 Amp.
Sinusoidal signal Maximum Consumption (1KHz) @ 12.6VDC: 547 Amp.
Dimensions (LxAxP): 229 x 65 x 447mm
Weight: 5.19Kg/11.44 lbs
Price: 600 shipped. Trade is possible. View attachment 26545534View attachment 26545535View attachment 26545536View attachment 26545537
Damping Factor: 400
Crossover:
