bgowdy
Heroes are remembered, but legends never die
Like the title says.
Amp is in great condition, i have not hooked it up since i have had it, it was bought slightly used from a friend, it was tested before i bought it from him and it was put back in the box and plastic and has been there since. No scratches that i have seen anywere on it other then mounting feet.
Im looking for 3k at 1ohm, The Ta1.3k is rated 3k @ .5ohm. Also its stable at .5 daily(the lowest THIS AMP has seen is 2ohms). Its 2.5k @ 1ohm. I know its only a 500watt difference just figured someone may be looking for .5 ohm daily stable amp so i figured id see whats out there.
So looking for 3k @ 1 or similar. I would really like a AP3k if anyone has one.....
SS Ta1.3000d Specs:
Tarantula Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 800 watts x 1 chan.
2 ohms: 1400 watts x 1 chan.
1 ohm: 2500 watts x 1 chan.
.5 ohm: 3000 watts x 1 chan.
Wired remote bass level control included
Military grade SMT PCB maintains dynamic performance
Audiophile grade IRTM transistors
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
Mono channel operation
Variable low-pass filter (40-220 Hz, 24 dB/octave)
Subsonic crossover: 13-49 Hz
Signal to noise ratio: 93dB
Three-way protection circuitry
Dimensions: 8"W x 20.50"L x 2"H
My Photos:
SS Ta1.3000d Specs:
RMS Power Rating:
My Photos:
