Mint Soundstream Rubicon 4.600
pimpnyou204
Became extremely frustrated last night (cut wrong side of box and scuffed my car with the box afterwards.) So im selling my stuff and going very simple. 1 12 or 10 or 2 8s but at most 2 10s. I have a coupe and theres just not enough space in it for 2 large 12s. Like 4 month old Soundstream Rubicon 4.600 class A/B amp. Far as i remember that is not a single scratch but i can double check if asked. It was ran at 4 ohm and never below 13v (awesome electrical.)
Rubicon Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
MOSFET PWM power supply
Platinum 4 AWG power block
Midnight blue finish with brushed accents
Selectable bass boost (0, 6, 12 dB at 50 Hz)
4/2-Channel operation
Speaker-level inputs with signal sensing for automatic turn-on
High and low level inputs
IDI (Intelligent Distress Indicator) for thermal, short, and impedance protection
Turn on/off delay
Heavy duty aluminum alloy heatsink for heat dissipation
Tri-mode capable
Nickel-Plated RCA level inputs
Nickel-Plated screw terminals
Infinitely variable crossovers with multipliers
Variable high-pass filter (15-4000 Hz, 24 dB/octave)
Variable low-pass filter (50-4,000 Hz, 24 dB/octave)
Frequency response: 10-35,000 Hz
Signal-to-Noise Ratio: 105dB
THD (Total Harmonic Distortion): 0.02%
Damping Factor: >250
Signal Voltage Range: 200mV - 6V
Power Voltage Range: 11V - 16V
Dimensions: 15-3/8"L x 8"W x 2"H
10/10 physical and mechanical
140 shipped to continental US
Wow u know I just now noticed that and idk I assume I can just bend it back wtf lol not familiar with them if u post specs I'll check otherwise I'll have to look later but not too fond of alpine stuff personaly
pimpnyou204
pimpnyou204
Fort Lauderdale
Bassballer150
