Sold MINT LPG 25NFA Tweets and Hinge Mounts
whitedragon551
Moderator
1. Product:
2 LPG 25NFA German made tweets with Hinge mounts
2. Specs:
LPG 1" neodymium magnet tweeter.
Compact high efficiency dome tweeters with smooth and
extended frequency response.
Variable mounting to fit your applications.
Ferrofluid cooled for higher power handling.
Can be used in LPG wedge or hinged wedge mount.
Technical Data
Nominal Impedance 8ohm
DC Resistance Rdc 6.8ohm
Resonant Frequency fr 1850 Hz
Rated Power 80 W
SPL 1W/1m 92 db
Total Moving Mass MMS 0.22 g
Effective Piston Area SD 6.8 cm2
Voice Coil Diameter 25 mm
Voice Coil Former Nomex
Voice Coil Length 1.5 mm
Voice Coil Layers 2
Flux Density B 1.35 Tesla
Force Factor BL 2.4 Tm
Gap Height 2 mm
Magnet Diameter 32 mm
Magnet Height 8 mm
Magnet Weight 0.05 kg
Mass of Speaker 0.07 kg
Flange diameter 48 mm
Cutout hole Ø 46 mm
Depth 10 mm
8 ohm
FS Hz 1850
Power @ 12db 80
db 283 v/m 92
Datasheet download with frequency response charts:
https://www.madisound.com/store/manuals/25nfa.pdf
3. Description/Condition:
MINT
I have soldered my left over 16 awg American Bass OFC speaker wire on and heatshrunk it to prevent the new owner from taking the tweets out of the mounts to tell what side was positive and negative.
One reads 6.7 and the other 6.8 ohms.
4. Price: :
$65 shipped for the pair
5. Pictures:
Attached
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
