N nbudros 10+ year member E-THUG 1,328 0 DFW, TX Nov 8, 2006 #1 Would a memphis belle be perfect for powering active setup: 2 AA 6" Poly Mids 2 AA Tweeters 1 AA Arsenal 15" All at the same time? Could i do an active setup with this amp? Any thoughts on if this system would work correctly. Click to read more...
JimJ 5,000+ posts Tangled Up in Blue 32,922 107 Hillsborough, NC Nov 8, 2006 #3 You'd need a head unit with 3way active capability...or an external crossover unit.
OP N nbudros 10+ year member E-THUG 1,328 0 DFW, TX Nov 8, 2006 Thread Starter #4 Oh really... =( I couldnt just set rear input to HPF high enough for the tweeters? set the front input to HPF lower to be perfect for mids? then set LPF for my sub?
BassAddictJ 5,000+ posts CarAudio.com Veteran 13,568 23 FL Nov 9, 2006 #5 Oh really... =( I couldnt just set rear input to HPF high enough for the tweeters? set the front input to HPF lower to be perfect for mids? then set LPF for my sub? Click to expand... should work.............might as well just get some components and run 4 compoent set off the ***** lol......or run 2 comp sets and bridge it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
