talon2nr7588
how much more does a sheet of 1" mdf weight as compared to a sheet of 3/4" MDF?
No way in he!! a 3/4" x 49 x 97 sheet of mdf weights 71 lbs unless it the Ultra Light Weight MDF because I get the info directly from the distributor that has the Manufacturer's Specification Sheets and a 12" x 12" x 3/4" piece of mdf weights 3 lbs.Sheets are sold in 48x96x ? in
1in=.0254m
For 3/4" thickness:
0.01875 m^3
1.2 m^3
2.4 m^3
V 0.054 m^3
density 600 kg/m^3
mass 32.4 kg
weight 71.28
For 1" thickness:
0.025 m^3
1.2 m^3
2.4 m^3
V 0.072 m^3
density 600 kg/m^3
mass 43.2 kg
weight 95.04
Once again:
71.28 * 1.33 = ~ 95 lbs.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That was using the lowest density. MDF has a density of 600-800 kg/m^3 give or take.No way in he!! a 3/4" x 49 x 97 sheet of mdf weights 71 lbs unless it the Ultra Light Weight MDF because I get the info directly from the distributor that has the Manufacturer's Specification Sheets and a 12" x 12" x 3/4" piece of mdf weights 3 lbs.
I understand what you saying, however, most mdf in terms of density hovers in around 3lbs per sq.ft. and the math I use breaks that weight down to the sq.in. weight and it is the most common material sold in HD, Lowes and so forth.That was using the lowest density. How's this:
3/4"
0.01875 m^3
1.2 m^3
2.4 m^3
V 0.054 m^3
density 800 kg/m^3
mass 43.2 kg
weight 95.04
1"
0.025 m^3
1.2 m^3
2.4 m^3
V 0.072 m^3
density 800 kg/m^3
mass 57.6 kg
weight 126.72
My point was that it's a simple ratio. 3/4" weight * 1.33= 1" weight. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I've used UL MDF to build many enclosure's and to be quite honest I didn't find any kind of drawbacks per say other than the enclosure weighing in alot less than standard mdf.While on the subject of UL MDF, what is your experience with it?
Is it simply lighter with no drawbacks in the subwoofer box application?
Also, how much can one expect to pay for it? None of my local stores carry it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Hmm... I would have to say the exact opposite. I never have screws strip out in trupan (Lightweight MDF) but had it happened way back when I used to use MDF.I've used UL MDF to build many enclosure's and to be quite honest I didn't find any kind of drawbacks per say other than the enclosure weighing in alot less than standard mdf.
Though some folks have said they can tell the difference in bass response between the two which is total BS because no one that I have ever made the comparison with the two different material types could tell the difference.
The only other nick picky issue is when mount the sub to the enclosure, the screws tend to strip the UL MDF more easily, but, that can be said for any material if a screws are driven in with to much torque.
It amazes me that all the cordless drills now a days have torque clutch settings at the head of the drill and if people would learn to use them, then they wouldn't be stripping out screws in MDF.
Well, where I get my material from a sheet on UL MDF runs around $ 33.00 for a sheet of 3/4" vs $ 22.00 for standard 3/4" MDF and if people would quit buying into all the d@mn myths about certain materials and their usage for subwoofers enclosure's, then they would save a fews bucks here and there.
