Manufacture Rocommended Encloser?
  • 4
Originally posted by Jmac The maximum dimensions of your trunk (Or wherever the box will go) in inches //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
31" w x 15" h x 16" d
d= if you can make it as small as possible
Originally posted by Jmac In that case ...
Option #1
Construction Material = .75" MDF
Box Height = 15"
Box Width = 33.5" (33.5" minus .75" divider = 32.75")
Box Depth = 12"
Box Volume = 1.21 ft^3 per chamber
Box Qtc = 0.795
F0 = 70.3 Hz
F3 = 40.8 Hz
F6 = 32.4 Hz
F9 = 26.7 Hz
Option #2
Box Height = 15"
Box Depth = 8"
Box Volume = 0.72 ft^3 per chamber
Box Qtc = 0.95
F0 = 58.5 Hz
F3 = 44.5 Hz
F6 = 36.9 Hz
F9 = 31.3 Hz
Whats the difference between the two?
which one would sound better?
and once again thank you
P.S. How much do I owe you?
these subs are rated at 350w rms each and im powering them with a VR1000d so they are getting about 500w rms would that also make a difference?
The recommende encloser is 14.5"h x 33.5"l x 10"d according to crossfire would this spec be better that yours or are yours better?
Originally posted by Jmac In that box, power handling will drop. The box I recommended (0.8 ft^3 per chamber) should be able to handle that amp. I can't guarantee a box that is 19% larger will be able to handle 1000 watts continuously ...
so in my case smaller is better, correct?
What the smallest I can go?
I want SQL
Originally posted by Jmac The 0.8 ft^3/chamber box I listed would be the largest you should use //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif You don't want to go super, super small because it will sound like **** ...
Would this one still soung good or should I wire my subd to 2ohms and make a bigger box?
Well Jmac I'm of to make my first box I really appreciate your help. If theres anything I can do let me know. Thank you once again. I tried to do it myself in WinISD PRO but I could'nt figure it out.
Originally posted by Jmac That's what I get payed for //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Anyone know where my paycheques are ? I thought I got $1 per helpful post ... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
uhh...wouldn't that explain why you haven't gotten any?? LOL
Originally posted by Jmac LOL
That's just mean !!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my bad...i'll send you youre $3 check tomorrow...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
TRAVIESO
TRAVIESO
CA
violator5spd
    May 18, 2024
    May 18, 2024
