Sold Make Me an Offer
Madlduke
I am selling two (2) Kicker KX2500.1 Amps and four (4) Brand new KICKER Solo-Baric L5 S12L54 12” Subs $2000 or MAKE ME AN OFFER!
SKU: S12L54
FOR SALE IS THE 2006 MODEL OF THE S12L5 » 12" subwoofer with dual 4-ohm voice coils » SoloKon aluminum-treated composite cone with Santoprene rubber surround » frequency response: 20-100 Hz » power range: 50-600 watts RMS (300 watts per coil) » peak power handling: 1,200 watts » sensitivity: 87.9 dB » mounting depth: 6-3/4" » sealed box volume 0.88-2.0 cubic feet » ported box volume: 1.75-3.25 cubic feet
Kicker KX2500.1
2500 watts x 1 Class D Mono Amplifier
KEY FEATURES OF THE Kicker KX2500.1 ARE:
# Class D Mono Amplifier
# RMS Power Rating:
* 1500 watts x 1 chan. @ 4 ohms
* 2500 watts x 1 chan. @ 2 ohms
# SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal) Protects amplifier from accidents and undesired operation
# MOSFET Power Supply Provides high efficiency operation
# KickBass Variable bass boost circuit which provides up to 18 dB of boost at 40 Hz
# Full-time Variable Crossover 12dB lowpass variable from 50-200Hz
# Subsonic Filter Switchable (ON or OFF) speaker protection filter set at 12dB/octave @ 25 Hz
# High & Low level inputs
# RCA Output: 1 Pair
# Custom tooled gold plated connectors
# Remote Bass Level Control
# EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
# Dimensions (with end shrouds): 30-9/16"L x 10"W x 2-1/2"H
Madlduke
Madlduke
Houston
BassAddictJ
