Ls2's attempt at clean install..w/false floor...*PICZ*
ls2poweredgoat
Womanizer
Usually whenever I install an amp I do it half-assed, with a joke of a false floor too...
So when I got my new amps the other day, I figured I'd take a whack at making it look nice...
Minus the remote turn-on wire (ran out of day light, had to rush it), I think I did an A-OK job. No anywhere NEAR as nice as some other installs on here...but I think it's fairly clean...
I plan on fixing the remote wire this week, so it will really look clean then...
Give me your thoughts/tips on how to make it look better.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Now I plan on leaving that AS-IS for the most part, with exception to the remote wire, and I'm going to run a SQL 10/12 off my NINe.2x with a wide, narrow box with the NINe.2x mounted on the back so you won't even see it...and I'm going to re-locate the battery to the trunk, behind the rear seat..probably a Yellow Top or HC1400.
carpet the false floor... then add gromets to the holes... it will be teh seckz //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
Not a bad start, I'm curious to see what box you put in because we have close to the same car (2001 Acura CL) and I would like to do the whole "wide and narrow" box design. Also where's the Xtant in this???//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Later
Not a bad start, I'm curious to see what box you put in because we have close to the same car (2001 Acura CL) and I would like to do the whole "wide and narrow" box design. Also where's the Xtant in this???//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifLater
Sold the Xtant a few weeks ago.
The box will fit right underneath the 6x9 holes and fill up the area, mostly with width.
you made an attempt //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
j/p nice work //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
looks good :verymad:BTW that xtant dont touch my OEM's:verymad:
Sorry mang, it did mine justice...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Bridge it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
ls2poweredgoat
