LPG 26NA
Tweeters are in perfect condition and were only ran about 3 months. These are amazing tweeters for the money.
LPG 1" neodymium magnet tweeter.
Compact high efficiency dome tweeters with smooth and
extended frequency response.
Variable mounting to fit your applications.
Ferrofluid cooled for higher power handling.
Can be used in LPG wedge or hinged wedge mount.
Technical Data
Nominal Impedance 8ohm
DC Resistance Rdc 6.8ohm
Resonant Frequency fr 1850 Hz
Rated Power 80 W
SPL 1W/1m 92 db
Total Moving Mass MMS 0.22 g
Effective Piston Area SD 6.8 cm2
Voice Coil Diameter 25 mm
Voice Coil Former Nomex
Voice Coil Length 1.5 mm
Voice Coil Layers 2
Flux Density B 1.35 Tesla
Force Factor BL 2.4 Tm
Gap Height 2 mm
Magnet Diameter 32 mm
Magnet Height 8 mm
Magnet Weight 0.05 kg
Mass of Speaker 0.07 kg
Flange diameter 48 mm
Cutout hole Ø 46 mm
Depth 10 mm
$65.00 shipped
Shipping to Cont. 48
References in signature and heatware under Copyright21.
LPG 26NA
Technical Data
Rated Power 80 W
SPL 1W/1m 92 db
Voice Coil Layers 2
Gap Height 2 mm
Magnet Height 8 mm
Cutout hole Ø 46 mm
Depth 10 mm
$65.00 shipped
