Loudest 12's
njcc, i seen where some guys on soundillusions told me not to get them bc they go pop easy, i have also seen a video of shane after seeing the vid thats why i considered H2's.
LMAO..... Riiiiigggghhhht.
Find Shane @ TPro or Sin. He ran >4kw to each of his H2's in his truck for daily.
Yes Really.
And I have one of his H2's in my truck now w/~1kw per... daily. And I'm not even a fan of Orion's woofers persay.
BTW, I've heard that any woofer will pop with too much power in a bad enclosure. Ever plug one into a socket free-air?
Shane will even tell you that the H2 is a finicky sub.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yah... i've had a few chats with him. Awesome guy. But if you use commone sense, you are going to have no problems.
Hey, to each his own.
common sence as in i would think would be dont power over RMS for daily, and yea, i would be giving these woofers 800 a peice daily a for while then bump it up to 1600w a peice daily so i should be good in one sence
With a decent enclosure you should be fine @ 1600. As i said, I feed mine 1kw each now. I ran them @ 2kw nominal for some time too.
There are other good options out there though.
woulda DP be an all around louder sub do you think, with the amount of space i have to work with, i emailed TREO about a price on SSX would an SSX be more of a SPL geared woofer if so sould i look into one of those, and put that in a big box, im open to options, i basically want 2 spl type woofers that wont sound like crap
I've got an Orion h2 15" dual 2 ohm in a 2.25 cubic foot slot port enclosure tuned to 33 Hz being powered by an orion 1200d amp with 2 bulk packs of dynamat extreme in back and the sub still shakes the entire underbody of car. I've had people listen to it at half volume for a couple of seconds and immediately get out b/c they say their brain is literally shaking around in their head. By the way, h2 is 1.14" xmax one way (29 mm)
.....I've had people listen to it at half volume for a couple of seconds and immediately get out b/c they say their brain is literally shaking around in their head. By the way, h2 is 1.14" xmax one way (29 mm)
Depends on the Install... :boobies:
i dunno, what do you guys think, DP's, SX's, H2's or MTX 9512's, atomic ELE's ( not alot of people know about these subs ) or sonic FX ( the loudest one's ), which one of these subs will perform better in 2 to 3 cuic feet each ? i want the loudest 12's
boomzabit
boomzabit
Minnesota
awinter
