Linear Power HV series 5 amps and other stuff
T03SQ
Eclipse CD8445 w/remote
AudioControl FOUR.1i
2 Linear Power 3.2HV
3 Linear Power 2.2HV
CD Audio SatNet 456 passive crossovers
Dynaudio System360
Crystal CMP12 4ohm SVC
2 Elemental Designs 15A.22 2ohm DVC
Streetwires CBR44 with 100A AFS fuses
Eclipse CD8445 w/remote - In great working order and cosmetic appearance. I have a double-din mounting sleeve for the HU which I'll include if requested. There might be a wiring harness required which I do not have. See pictures for what is available.
AudioControl FOUR.1i - Only used a couple of weeks. Comes with box and manuals. Missing a small wiring harness which I believe only costs $10 on ebay.
2 Linear Power 3.2HV - In great working order
3 Linear Power 2.2HV - All 3 amps are faulty. 2 amps have a lead turn-on circuit issue which causes the amp to delay turning on for about 5 to 10 minutes. 1 amp will overheat quickly even with little to no source signal. TIPS will refurbish for $150 each.
CD Audio SatNet 456 passive crossovers - Never used. 1 is missing a CD Audio sticker.
Dynaudio System360 - Set is in working order but has some flaws. Grills are dented and have some rust. Mounting rings for midbass speakers are snapped on 1 or both sides. The dents in the 3.5" midrange speakers are pushing against the dome (I would suggest replacing those).
Crystal CMP12 4ohm SVC - In great working order. Cone has a couple of cosmetic blemishes.
2 Elemental Designs 15A.22 2ohm DVC - In great working order and cosmetic appearance.
Eclipse CD8445 w/remote - $200 shipped
AudioControl FOUR.1i - $150 shipped
2 Linear Power 3.2HV - $1000 shipped each
3 Linear Power 2.2HV - $500 shipped each
CD Audio SatNet 456 passive crossovers - $50 shipped
Dynaudio System360 - $400 shipped
Crystal CMP12 4ohm SVC - $175 shipped
2 Elemental Designs 15A.22 2ohm DVC - $200 shipped each or $375 shipped pair
Streetwires CBR44 with 100A AFS fuses - $60 shipped
Shipping only to US 48 states. Discounts for local pickup in Minneapolis metro. Will also give a sealed box for the Crystal CMP12 if purchased locally.
User name with all items FS.
More pictures
T03SQ
T03SQ
Minneapolis, MN
eg9
